TwinTurbo.NET: Nissan 300ZX forum - Re: And when the engines cold it does surge pretty
WazTTed
on May 24, 2012 at 3:51 PM
posted by Evan_Wright (Ca)
on May 23, 2012 at 10:03 PM
yup i get surging aswell when cold and hunting normally when coming off the throttle to idle sucks :( only thing i found was raising the idle to over 1k sorted this issue out but then you rjust chewing juice
Poor sealing Z1 tb's and how they effect idle control...
Evan_Wright (Ca)
21:01:01 05/23/12
Does it surge more when cold, and smooth out when warmed up?
BoneZ (MD)
21:34:16 05/23/12
Tps sits at .38 volts and shows closed tps "on". I can't
Evan_Wright (Ca)
22:02:20 05/23/12
Evan_Wright (Ca)
22:03:34 05/23/12
Unfortunately I swapped out the entire upper plenum which
BoneZ (MD)
22:16:24 05/23/12
Re: And when the engines cold it does surge pretty -
WazTTed
15:51:46 05/24/12
You might have to grind a bit of the plastic tab away
Stadsport (PHX)
02:26:08 05/24/12
I've all ready slotted my tps and grinded some plastic away.
Evan_Wright (Ca)
08:03:55 05/24/12
Have you tried to set TPS between 0.4V and 0.5V?
jschrauwen
08:52:36 05/24/12
I can and have had it at around .42 volts but honestly in
Evan_Wright (Ca)
11:01:54 05/24/12
Re: Poor sealing Z1 tb's and how they effect idle control...
MaxxAction
23:00:55 05/23/12
Yes, I sync'd them before dropping the motor in. (n/m)
Evan_Wright (Ca)
23:17:51 05/23/12
MaxxAction
23:05:34 05/23/12
Stadsport (PHX)
02:22:59 05/24/12
Yes, I've tried going up and down on the percentages and
Evan_Wright (Ca)
07:57:05 05/24/12
Then I agree with you on both points/ideas
Stadsport (PHX)
13:41:46 05/24/12
Yes I have. I actually did it a second time before
Evan_Wright (Ca)
14:13:46 05/24/12
Re: Then I agree with you on both points/ideas
MaxxAction
19:03:32 05/24/12
I have similar issue and believe it to be TB related.
Boosted1
06:11:58 05/24/12
Additionally, my TPS idle voltage is at 0.45 volts
Boosted1
06:15:50 05/24/12
Are you running 2.5" Intake Piping?
jschrauwen
08:57:35 05/24/12
NEGATIVE. Do NOT restrict the hose to the IACV - the
Ash's Z
09:38:52 05/24/12
You've got mail :-) (n/m)
ConVerTT
09:42:15 05/24/12
FALSE!!! It is "pull" not "push" at idle ....
ConVerTT
09:41:29 05/24/12
Re: FALSE!!! It is "pull" not "push" at idle ....
jschrauwen
11:15:01 05/24/12
Do you not realize your advice is not wanted here?
Aqualung
14:57:30 05/24/12
Re: Do you not realize your advice is not wanted here?
ZPHILE
22:16:52 05/24/12
your sig is too long
Adam (NoVA)
12:48:58 05/25/12
